1841 router behind a DSL modem in bridge mode as a PPPoE client
Jul 3rd, 2009
I have setup a configuration for a 1841 router to connect to the ISP using a dsl modem in bridge mode. I use my computer connected to the dsl modem in bridge mode and it works using windows xp pppoe client perfectly. But the router doesn't connect. This is the setup i'm using:
vpdn-group 1
request-dialin
protocol pppoe
interface FastEthernet0/1
description WAN Interface
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname <<Username>>
ppp chap password 7 <<Password>>
ppp pap sent-username <<Username>> password 7 <<Password>>
ppp ipcp route default
ppp ipcp address accept
ip route 0.0.0.0 0.0.0.0 Dialer0
any help will be appreciated. The debugs only show sending PADR. But I know the dsl modem is working because with the pc using windows pppoe client I can connect well.
paolo bevilacqua Sat, 07/04/2009 - 02:09
  • Hall of Fame,
    Founding Member
Maybe you need to clone the MAC from the PC, or ask ISP to release whatever MAC reservation.
In any case, it would be better for you to use an ADSL model like an 871 or 1801.
paolo bevilacqua Sun, 07/05/2009 - 23:24
  • Hall of Fame,
    Founding Member
debug pp is irrelevant in this case, as the OP mentioned PPPoE doesn't start at all.
Jose Robles Mon, 07/06/2009 - 06:07
This are the debugs and the output of them. These is all I'm seeing. I opened a TAC case and the engineer confirmed the configs are ok. The weird thing is that with my pc works fine every time so I have nothing to say to the ISP.
Router# sh debugging
PPPoE:
PPPoE protocol events debugging is on
PPPoE data packets debugging is on
PPPoE control packets debugging is on
PPPoE protocol errors debugging is on
PPPoE elog debugging is on
PPP:
PPP authentication debugging is on
PPP protocol negotiation debugging is on
Log Buffer (2000000 bytes):
*Jul 3 15:36:34.235: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern et0/1, changed state to up *Jul 3 15:37:01.575: padi timer expired *Jul 3 15:37:01.575: Sending PADI: Interface = FastEthernet0/1 *Jul 3 15:37:01.575: pppoe_send_padi:
FF FF FF FF FF FF 00 24 C4 87 75 CD 88 63 11 09
00 00 00 0C 01 01 00 00 01 03 00 04 63 5E 34 2C ...
*Jul 3 15:37:01.615: PPPoE 0: I PADO R:0090.1a42.157a L:0024.c487.75cd Fa0/1
00 24 C4 87 75 CD 00 90 1A 42 15 7A 88 63 11 07
00 00 00 84 01 02 00 0F 4A 55 4E 43 41 50 2D ...
*Jul 3 15:37:03.623: PPPOE: we've got our pado and the pado timer went off *Jul 3 15:37:03.623: OUT PADR from PPPoE Session
00 90 1A 42 15 7A 00 24 C4 87 75 CD 88 63 11 19
*Jul 3 15:37:13.863: OUT PADR from PPPoE Session
*Jul 3 15:37:13.863: PPPOE : Resending PADR *Jul 3 15:37:24.103: OUT PADR from PPPoE Session
*Jul 3 15:37:24.103: PPPOE : Resending PADR *Jul 3 15:37:34.343: OUT PADR from PPPoE Session
*Jul 3 15:37:34.343: PPPOE : Resending PADR *Jul 3 15:37:44.583: OUT PADR from PPPoE Session
*Jul 3 15:37:44.583: PPPOE : Resending PADR *Jul 3 15:37:45.403: %SYS-5-CONFIG_I: Configured from console by console *Jul 3 15:37:54.987: OUT PADR from PPPoE Session
*Jul 3 15:37:54.987: PPPOE : Resending PADR *Jul 3 15:38:05.227: PPPoE : Shutting down client session *Jul 3 15:38:05.227: [0]PPPoE 0: O PADT R:0000.0000.0000 L:0000.0000.0000 Fa0/
00 00 00 00 00 00 00 24 C4 87 75 CD 88 63 11 A7
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
*Jul 3 15:38:05.227: PPPOE : Resending PADR Router#
paolo bevilacqua Mon, 07/06/2009 - 06:44
  • Hall of Fame,
    Founding Member
As mentioned before: ISP may have cached PC MAC address and ignoring requests coming from other MACs.
