Cisco Bars - Web Error : Failed to create ASP object
Answered Question
Jul 3rd, 2009
I have installed ;
Win2003
framework ASP .net2
IIS
MSDE 2000 serveur
Cisco BARS Version 4.0.12
When I go to http://IP/BARS
It ask for password, then I see the usual interface, but then I go and choose a backup option and I allways have this error
Windows Internet explorer
Failed to create ASP Object for : _RemoteScripts/rs_BARSconfig.asp
Firefox show that error :
Error:
Cannot locate proxy which supports Remote Scripting.
Was RSEnableRemoteScripting method invoked?
Second popup :
Failed to create ASP object for : _RemoteScripts/rs_BARSconfig.asp
Overall Rating: 5 (1 ratings)
philippe.cousineau Fri, 07/03/2009 - 19:06
thanks a lot, it fix my problem verry well.
Another little one :)
have any idea of this one here ?
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.2; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727)
Timestamp: Sat, 4 Jul 2009 03:06:10 UTC
Message: Object doesn't support this property or method
Line: 269
Char: 3
Code: 0
URI: http://localhost/BARS/_ScriptLibrary/rs.htm
Message: 'rsConfig' is null or not an object
Line: 199
Char: 3
Code: 0
URI: http://localhost/BARS/BARSserverConfig.asp
