Regarding VPN configuration
Jul 3rd, 2009
Hi All,
I have one basic question about vpn configuration if we can create vpn between two routers or firewalls also then what is requirement of seprate device like cisco concentrator.
sharma16031981 Sat, 07/04/2009 - 00:36
that I know but my query is why seprate device is required like VPN concentrator when router can do
Well I think it comes from the ethos, of let a router be a router, let a switch be a switch.
Back in the day - if you wanted VPN's you had a concentrator, but then I suspect Cisco started to listen to it's customers. Then VPN's and Firewalls are in the IOS of routers, dynamic routing is coded into Firewalls. Firewalls/Routers performing IPS/IDS/SPAM/SSL etc
I think it's a system of consolodation, one device does all.
