CIPC and PSTN access when using low bandwidth codec
Jul 4th, 2009
  • Silver, 250 points or more
Got CUCM 6.1.3 with MGCP controlled gateway with access to PSTN.
When I use softphone and g729 codec (marked option optimized for low bandwidth) all calls to PSTN are connected but both way no voice as g729 is a codec.
Tried to use transcoder but still same issue.
How to force CIPC to use different codec on calls to PSTN?
david-lima Sat, 07/04/2009 - 07:11
  • Bronze, 100 points or more
Hi, your CIPC is in your HQ or remote office?
To force to G711 you need to configure a device pool and a region with G711 (within this region) and G7XX (with other regions) and assign this device pool to the CIPC configuracion.
Hope this help
David
KonradStepniewski Sat, 07/04/2009 - 07:54
Doesn't matter where is my CIPC. When I use softphone in region where G711 is only codec it use g729 with local gateway when option is marked.
