cisco unity 5.0
Jul 4th, 2009
i try to integrate unity 5.0 with one cluster ( publisher(backup) and subsriber(primary)).
in the process of integration, when connection try to check voice ports, the process fail with subscriber end success with publisher.
schud i create voice port (wizard) just in the publisher or both publisher and subscriber. now i just make it in the publisher.
bsaid1977 Sat, 07/04/2009 - 01:29
thanks for your quick reply.
i have created : voice ports and pilot number and MWI like integration guide. and i can ping from unity server both publisher and subscriber. but always the unity can't check ports with subscriber( failed), is this a problem ?
when i press phone message button i don't hear anything.
KonradStepniewski Sat, 07/04/2009 - 03:50
Try to call pilot number. If I remember correctly you will need VM profile to use with message button.
From subscriber CM administration page you should see ports registered on publisher.
rate if this help.
