NAT OverLoad - Security concern
Jul 4th, 2009
Is this a secure NAT Overload configuration, what I mean "Nobody from Public Network can access private NATTED Box"
interface fa0/0
ip nat inside
interface s0/0
ip nat outside
access-list 100 permit ip 192.168.1.100 255.255.255.255 any
ip nat inside source list 100 interface serial 0/0 overload
paolo bevilacqua Sat, 07/04/2009 - 15:19
  • Hall of Fame,
    Founding Member
Correct, nobody from outside can access inside, all connections must be initiated from inside.
You can also use a standard ACL to the same effect.
pciaccio Sat, 07/04/2009 - 19:00
  • Silver, 250 points or more
If the 192.168.1.100 is in the INSIDE then this is good....
ronald.ramzy Sat, 07/04/2009 - 21:40
192.168.1.100 is ISA Server IP, will there be any performance impact using NAT OverLoad.
Is the following configuration Secured ( Anyone from outside cannot initiate connection )
********Configuration ******************
ip subnet-zero
ip domain lookup source-interface FastEthernet0/0
ip name-server 4.4.4.4
description Connected to ISP
ip address 10.10.10.66 255.255.255.224
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description Connection to LAN-Switch
ip address 192.168.1.100 255.255.255.0
ip accounting output-packets
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.65
ip route 172.20.16.0 255.255.255.0 192.168.1.1
no ip http server
no ip http secure-server
ip nat inside source static 192.168.1.101 10.10.10.68
ISA Server : 192.168.1.101
Public IP : 10.10.10.68
paolo bevilacqua Sun, 07/05/2009 - 09:11
  • Hall of Fame,
    Founding Member
You have been told already that is ok.
