css first?
Answered Question
Jul 4th, 2009
when a working phone is off hooked, and you started dialing, what are the process it undergoes...
-does it checked first the css? this is my understanding.
pls i just want to clear up thingds.
Correct Answer by Jaime Valencia about 7 years 6 months ago
mmm, it's a combination of what you have in the CSS and what you dial
The moment you go off-hook the possible matches are everything you can reach with your CSS, every digit you input goes to the DA and narrows the initial possibilities until no potential matches exist (just 1 match) or when you have potential matches (which would be overlapping dial plan)
If you use the DNA tool it will show you the outcome of the DA.
This is exactly the theory behind the PLAR config.
java
if this helps, please rate
Overall Rating: 4 (2 ratings)
islam.irshaid Sun, 07/05/2009 - 03:24
yes
A calling search space comprises an ordered list of route partitions that are typically assigned to devices. Calling search spaces determine the partitions that calling devices search when they are attempting to complete a call. For more detailed information on calling search spaces and partitions, refer to "Partitions and Calling Search Spaces" in the Cisco CallManager System Guide.
please rate if that help
Jaime Valencia Sun, 07/05/2009 - 08:13
When you go off-hook the DA starts processing the digits and matches them against the elements your CSS is allowed to reach to determine if you have permission to dial. This comprises the possible matches list you create as you dial.
Calling Privileges in Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/dialplan.html#wp1044276
I'd recommend you to read the whole doc.
java
Correct Answer
Jaime Valencia Sun, 07/05/2009 - 10:07
java
