Warning message
mva do not heard anyhing when teh calls is connect
Jul 5th, 2009
Hello I need to know why I do no heard anything when I dial from of pstn>GW H.323 > MVA
I have this configured :
dial-peer voice 6098 pots
service mva
incoming called-number 6098
direct-inward-dial
no digit-strip
port 4/0/0:0
dial-peer voice 76708 voip
preference 1
destination-pattern 6098
voice-class h323 1
session target ipv4:10.40.7.2
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
application mva
http://10.40.7.1:8080/ccmivr/pages/IVRMainpage.vxml
I have debug debug voice application vxml application attached
anyone can help me?
sheepate Mon, 07/06/2009 - 05:55
Do you have 3336796000 configured as a remote destination for any user? IS MVA enabled for that user's configuration?
How long does it take before the call is dropped?
santiago_figuer... Mon, 07/06/2009 - 07:07
Hello, I do not have configured this number as remote destination , 3336796000 is my caller id of PSTN, the calls is dropped at one minute without heard IVR.
sebastiandm Mon, 07/06/2009 - 07:20
Have you configured the 6098 number as your MVA on CUCM and also in your service parameters. Is the service enabled as well ?
santiago_figuer... Mon, 07/06/2009 - 07:30
I have other info:
G_3845#sh call application voice mva
Script Name : mva
URL : http://10.40.7.1:8080/ccmivr/pages/IVRMainpage.vxml
Type : Service
State: Registered
Life : Configured
Exec Instances: 0
Script Code Begin:
VXML Application mva
URL=http://10.40.7.1:8080/ccmivr/pages/IVRMainpage.vxml
Security Level: not trusted
27 incoming calls
0 calls handed off to it
0 call transfers initiated
0 pages loaded, 54 successful
0 prompt play attempts, 0 successful
0 recorded messages
The VXML Script is:
<?xml version="1.0" encoding="iso-8859-1"?>
http://10.40.7.1:8080/ccmivr/IVRGetAudioFile.do?srcdir=en_US&file=1.au"/>
http://10.40.7.1:8080/ccmivr/IVRCalleridLookup.do" method="get" namelist="remotedest srcdir"/>
http://10.40.7.1:8080/ccmivr/IVRGetAudioFile.do?srcdir=en_US&file=3.au"/>
http://10.40.7.1:8080/ccmivr/IVRCalleridLookup2.do" method="get" namelist="dest srcdir accessCount"/>
Leo Salcie Tejeda Tue, 10/16/2012 - 10:45
  • Gold, 750 points or more
Did you find a solution? I'm getting the same error. Call is conected but not prompt it hears, after some second the call is dropped...
Any advice would be appreciated
_____________________________
MDGDP, CCNA, CCNA Voice certified
