cm 5 phones/dn/macs to bat for use with 7
Answered Question
Jul 5th, 2009
-we have cm5.x with around 300 phones deployed..
-now we are having new hardware with cm7.02
i want to achieve the ff
-(do the reverse way actualy) of extracting out from cm5 an excel format for the phones along with the dn as well as macs to be use as bat to the new cm7..
note: cm5 did not used bat at all on their implementation
Correct Answer by Rob Huffman about 7 years 8 months ago
Hi Celso,
You could use the BAT Export from CUCM 5.x and then Import on CCM 7.x but the .csv files will need to be tweaked. The look and feel of BAT on 7.x versions is a little different so you would have to experiment with what fields need to change before the actual Import is done.
Cisco Unified CallManager Bulk Administration Guide, Release 5.1(3)
Exporting Phones
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_3/t03phexp.html
Cisco Unified Communications Manager Bulk Administration Guide 7.0(1)
Inserting Phones
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/7_0_1/t03inph.html
Hope this helps!
Rob
Overall Rating: 4 (1 ratings)
Correct Answer
Rob Huffman Sun, 07/05/2009 - 14:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Celso,
Exporting Phones
Inserting Phones
Hope this helps!
Rob
