VLAN support on ESW 500 switch
Jul 5th, 2009
How many VLANs does the ESW 500 switch support?
Maulik Shah Sun, 07/05/2009 - 13:19
The ESW 500 switch supports a max of 256 VLANs and can accomodate upto 8000 MAC addresses in the CAM table.
Note, by default on the POE switches, VLANs 1 (data) and 100 (voice) are enabled while on the non POE switches, only VLAN 1 (data) is enabled.
Velin Tsekov Wed, 08/17/2011 - 11:23
All,
Can you confirm that Cisco ESW5xx supports up to 256 VLANs ?
Velin Tsekov
rocater Wed, 08/17/2011 - 12:14
Hi Velin,
     As Maulik mentioned, the ESW500 series switches support up to 256 vlans.
