Configuring FXO card in CME 4.1
Jul 5th, 2009
I am having trouble getting inbound dialing working on an FXO card. I only get a sigle ring on the inbound call and then a disconnect and dialtone. Is there a sample config of having an inbound number ring through to a phone that i can use as reference?
abdulrahmancisco Mon, 07/06/2009 - 01:03
For configuring FXO you need to set; at a minimum, the call progress tone specific for your country.
For example if you are in Great Briton:
voice-port 0/0/0
cptone gb
For sending all incoming calls on a voice port directly to an extension 222, you can use plar.
voice-port 0/0/0
connection plar 222
Hope this helps.
