Help with setting up Metro Ethernet
mbroberson1
Level 3
Level 3
Can someone please help and give suggestions and possible configuration options for setting up metro ethernet in the following senario:
Will be setting up ME between headquarters and three remote branch offices. Each remote branch will be provisioned to 10MB, and the headquarters will have one link for the aggregate provisioned to 30MB.
My questions, we will have routers at the remotes, but how will this terminate at the headquarters? Do we connect the one ME aggregate connection to a router, or to a L3 switch? And how do you configure the headquarters devices to separate the traffic? Do you use sub interfaces like in frame relay? Please provide a sample config if possible.
16 Replies 16
guruprasadr
Level 7
Level 7
HI,
A. Terminate the ME links at the L3 Switch and configure the Sub-interface in the Router.
A. You can use Cisco MPLS-VPN Technology. Refer useful link below:
http://www.cisco.com/en/US/docs/net_mgmt/vpn_solutions_center/1.1/user/guide/VPN_UG1.html
Pls Rate if HELPS
Best Regards,
Guru Prasad R
So at the headquarters end I will bring the ME circuit into say my 6500. At the remotes I will have routers, is it here at the remotes where I will configure the "sub-interfaces"?
HI,
Assume you have 3560 SW at your HQ and where you can terminate the ME circuts.
Configuration in Switch as:
3560SW#sh run int Fa0/5
Building configuration...
Current configuration : 123 bytes
interface FastEthernet0/5
description ***************
switchport access vlan 40
switchport mode access
end
Create a SVI interface at the Router, the configuration is as:
7604-Backbone-RTR#sh run int Vl40
Current configuration : 119 bytes
interface Vlan40
ip vrf forwarding 1234-NAME-MESH
ip address xx.xx.xx.xx 255.255.255.252
end
In the above configuration, VRF is applied on Interface to make the pefix unique across the Backbone.
A. Yes, the case for remote is same as that of HQ.
Pls Rate if HELPS
Best Regards,
Guru Prasad R.
This helps, but one area I am uncertain of is with the configuration at the heaquarters L3 switch. When I connect the ME circuit into my 6500, how will I define the separation in traffic between my remove sites? In the configuration above it has a simple switchport configuration for the headquarters switch. If the ME circuit is HUB and spoke like "see attachment" how will at the headquarters define the traffic from site 1, site 2, etc...? I know how this works in frame relay with DLCI's, but ME is where I am uncertain in this regard.
HI,
The requirement looks like HUB & Spoke topology and you want all your Spokes to communicate with the HUB only and no inter-communication between the spoke offices.
You can Ethernet over MPLS between the HQ and Remote Sites. The configuration looks simple over Ethernet Circuit.
HQ Router:
interface GigabitEthernet0/3.xxx
description ****To Site1****
encapsulation dot1Q xxx
no cdp enable
xconnect abc encapsulation mpls
end
Site1 Router:
description ****To HQ****
no cdp enable
mpls l2transport route abc
end
Note:
Command: xconnect abc encapsulation mpls
Command: mpls l2transport route abc
end
The above 2' commands are same, the CLI varies in Cisco based on the IOS Software Version.
Hope I am Informative.
Pls Rate if Helps
Best Regards,
Guru Prasad R.
This, helps. The headquarters devices will be a L3 switch and the remotes will be routers? In the above config you have it as a router. Will this affect the config change? Also would I just add sub-interfaces at the headquarters for each spoke?
HI,
If it is a L3 Switch @ HQ, create SVI Interface and try for the 'configuration'
1' SVI interface for each remote offices will do.
HTH,
Guru Prasad R.
Ok, so will that SVI (VLAN interface I am assuming) have to be the same vlan number the provider gives me for each site, if the provider assigns a VLAN number for each remote site? Is this typically the way (AT&T) the provider will do it?
HI,
Yes, few providers will assign same VLAN No's end-to-end.
It is not mandatory for having the same VLAN No#, however, the VC ID should be same.
Best Regards,
Guru Prasad R.
So if I have a "hub-and-spoke" ME setup and routers (not switches) at the hub and spoke locations will I have subinterfaces on the hub router with dot1q for each coresponding vlan and at the remotes the same type of setup?
Yes, you should have dot1Q enabled at HUB & Spoke sites.
HTH,
Guru Prasad R.
In a similar topology, how do the remote sites connect to the Internet - is it through the HQ site, or does the metro ethernet connection at the branch give you the option to go straight to the Internet?
sjamison76
Actually after reading all these responses on this, its actually much easier than you think. (unless I missed something)
Since your doing L3 its very simple. Just create a IP WAN all in the same subnet and you will be good to go since its all on routers.
The Provider should then tag those IP's to route them within their Service Provider network within a vlan to your sites. It will basically be a broadcast network running around within its own vlan so to speak... That end point at your HQ will see all the other locations off that one connection.
Should be a piece of cake, we do this for lots of customers now, as well as provide transparent L2 lan services as well for customers who dont want a L3 WAN but pass all their vlans/broadcast/arp/stp/cdp and other protocols across the wan.
Stuart
Hi Stuart,
If I post a config snippet example could you tell me if it looks good?
Brandon
