Copying configuration from A to B on WISM
Answered Question
Jul 5th, 2009
  • Gold, 750 points or more
I'm curious if the process I'm using to replicate configuration between two controllers on a WISM is the best (quickest) method. If there's a better method with WCS, please let me know
- capture "show running-config" on controller A
- add "config" at the beginning of each line
- modify some lines like mgmt/ap-mnger IPs and interface IPs, passwords
- "recover-config" on controller B to ensure it has blank config
- disable 802.11a and 802.11b
- paste config script to controller B
- enable 802.11a and 802.11b
Please let me know if there's a better way to do this.
Correct Answer by Lucien Avramov about 8 years 2 weeks ago
On issue 1 :
You are right I see the same problem on 4.2 WLC.
On 5.2, you can see the config wlan portion that has the ssid name, in the file.
Issue 2 :
WLC to 5.2.157.0 and later has a new command to display AP
group config as you would see below:
(Cisco Controller) >show wlan apgroups
Site Name........................................ APGroup1
Site Description................................. ApGroup1
WLAN ID Interface Network Admission Control
1 management Disabled
2 vlan2 Disabled
3 management Disabled
AP Name Slots AP Model Ethernet MAC
Location Port Country Priority
LAP2 2 AIR-AP1131AG-A-K9 00:19:aa:6b:62:14
default location 29 US 1
Site Name........................................ APGroup2
Site Description................................. ApGroup2
1 vlan2 Disabled
2 management Disabled
LAP6 2 AIR-AP1131AG-A-K9 00:1c:58:dc:86:b8
Site Name........................................ Test
Site Description................................. Test
3 vlan2 Disabled
AP001b.d5de.993c 1 AIR-LAP1231G-A-K9 00:1b:d5:de:99:3c
Site Name........................................ default-group
1 vlan2 Disabled
Location Port Country Priority GroupName
The is a good command to capture the AP information
You are correct the AP-Group mapping is NOT stored on the controller config
I also explored the option of extracting the APs to AP-Group mapping
from the config file on the WLC but later realized that this mapping is
not stored on the controller config. Here is my explanation :
The AP Group to which an AP belongs
is stored on the config on each AP. So when an AP boots up, it would
look for the exact AP group name configured on it - no matter which WLC
it joins.
WLC version 5.2 had lots of improvement relating to the AP Group
feature. Here is link to the config document which provides more info
about how AP Groups are configured and function in this new version.
http://cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/
c52wlan.html#wp1128591
Overall Rating: 5 (1 ratings)
Lucien Avramov Sun, 07/05/2009 - 18:03
  • Red, 2250 points or more
In WCS, there is no easy method for copying the config. Be careful, copying a template config from one to the other does NOT copy all the configuration.
Nevertheless, on WCS, there is a background task you can run : Controller Configuration Backup.
This will store on the WCS locally tftp / ftp folder the configuration of your WLCs.
You can then edit it, and restore it on the other WLC's GUI for example.
Roman Rodichev Sun, 07/05/2009 - 18:21
If I'm not mistaken, the WLC XML config file doesn't store all details in clear text. For example, I believe that the WLAN names are stored in hashed format. I'm going to try to play around with XML file, but I was wondering if copying command line config script (show running-config) is a better idea?
Lucien Avramov Sun, 07/05/2009 - 18:33
I just tried on a 5.2 controller which is XML.
The SSID appears in clear text as for example here:
config wlan create 2 Test-WLAN Test-WLAN
When you use the config backup on the WCS, the config should be in clear text backed up in the TFTP directory of WCS.
Roman Rodichev Wed, 07/08/2009 - 21:54
I'm running 4.2 on controller and WCS, and I just tried what you suggested. It appears that the backup config file is basically the same XML configuration file you can get from the WLC directly. Most of the information stored is not in clear text. So here's my WLAN:
6363696500000000000000000000000000000000000000000000000000000000
ENABLED
1800
note that the profile name is not in clear text.
So I guess doing "show running-config" is my only option to replicate configuration.
There's one more thing I noticed. The AP related configuration (for example AP-group name) is not stored in the XML file and is not stored in the clear text running-config. Strange. I guess it's actually stored right on the AP, but I find it hard to believe that all AP-related configuration settings are stored right on the AP, I would think it's stored on the WLC, I could be wrong though.
In other words, I can't find the following settings stored in "show running-config" or XML file:
(Cisco Controller) >show ap config general AP1130
Cisco AP Identifier.............................. 11
Cisco AP Name.................................... AP1130
Country code..................................... US - United States
Regulatory Domain allowed by Country............. 802.11bg:-AB 802.11a:-AB
AP Country code.................................. US - United States
AP Regulatory Domain............................. 802.11bg:-A 802.11a:-A
Switch Port Number .............................. 1
MAC Address...................................... 00:21:d8:37:33:40
IP Address Configuration......................... DHCP
IP Address....................................... 172.16.7.101
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 172.16.7.1
Telnet State..................................... Disabled
Ssh State........................................ Disabled
Cisco AP Location................................ default location
Cisco AP Group Name.............................. vlan5
Primary Cisco Switch Name........................ WLC2106A
Primary Cisco Switch IP Address.................. 3.45.47.144
Secondary Cisco Switch Name...................... WLC2006B
Secondary Cisco Switch IP Address................ 3.45.47.143
Tertiary Cisco Switch Name.......................
--More-- or (q)uit
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Global: Disabled, Local: Disabled
Remote AP Debug ................................. Disabled
S/W Version .................................... 4.2.176.0
Boot Version ................................... 12.3.8.0
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... 00:11:20:7f:72:af
Correct Answer
Lucien Avramov Wed, 07/08/2009 - 23:30
On issue 1 :
Issue 2 :
2 vlan2 Disabled
1 vlan2 Disabled
3 vlan2 Disabled
1 vlan2 Disabled
it joins.
Roman Rodichev Wed, 07/08/2009 - 23:38
thanks for the info, it clears up some of the confusion I had. I'm finding other pieces of information that are not stored in the running-config. Basically all AP information is not stored on WLC, and also I just found that not all WLAN information is stored in running-config. For example all WPA settings and AAA radius server for the WLAN doesn't show up in the running-config (I'm sure they are in XML file). I'm pretty sure that stuff is stored on the controller, but wasn't included into show running-config, right? I'm basically looking for a quick and easy way to replicate as much config as possible between WISMs on 4.2, and it appears as if you really have to know which stuff is stored on WLC, which stuff is stored on WLC but doesn't show up in running-config, and which stuff is not stored on WLC at all.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
