translation table behavior due to change in routing on FWSM
Jul 5th, 2009
I want to know what will be the behavior or xlate entries if traffic to a destination changes the outgoing interface due to a routing change. The xlate timeouts are set to its default value.
Is there any automated way beside clearing the xlate table.
Zoheb
vkapoor5 Fri, 07/10/2009 - 13:48
  • Bronze, 100 points or more
The PIX Firewall does not clear the translation table automatically, as defined by the xlate timer. The sh timeout command output shows the timeout value configured on the PIX for connections and xlates.
