Advantage of NAT in ASA 5510
Jul 5th, 2009
Dear All,
I configured my ASA 5510 without NAT by using the command
no nat-control
DMZ, Inside and outside interfaces are configured,
Static routes are configured for inside networks,
What is the Advantage of using NAT in ASA??
pieterh Mon, 07/13/2009 - 03:36
nat is used when you
- want local hosts with a private adress made reachable from the internet (private adress range is not routed on the internet).
- want to hide your local adresses for the outside world
- got a limited number of public adresses.
then you can create a pool of public adresses where multiple inside adresses can use the same outside adress
- you local adresses (say 10.1.1.0/24) are also used at a remote site you are connected to.
then your 10.1.1.0 subnet can seem like 172.168.1.0/24 to the remote side.
(remote side must also do NAT to make all work)
junshah22 Mon, 07/13/2009 - 07:04
I am using PAT at my Router, I have one live IP for PAT,
Router is Directly connected to the Internet, PAT is configured at router
ASA is in place very next to the router,
ASA has three Interfaces configured
1- DMZ
2- Inside
3- Outside
Outside interface is connected with Router
Inside interface is connected with Core Switch
DMZ is connected with servers switch
security level for DMZ = 50
Inside = 100
Outside = 0
static routes towards inside vlan interfaces are configured on ASA
nothing else is configured,,
I am using ASA 5510 security plus
MY QUESTION IS:
how can I confirm that ASA is protecting my network from outbound threats
how can I confirm that IDS/IPS is working properly..
I configured my ASA using command line,
I dont have CSC SSM Module, but my ASA has capability of it
Please advise me, how can I configure my ASA for securing my network,
If it is protecting, how can I confirm it..
Junaid
