After rebooting the primary pix , failover configuration going remove autom
Jul 5th, 2009
We observed atter rebooting or reloading the primary box failover related configuration is automatically removing from the primary box. H/W model Pix-525 and image ver: 6.3.5
It will very help me if some can help me on this.
tprendergast Mon, 07/06/2009 - 11:27
  • Silver, 250 points or more
Check your licensing... Also, double check that when you configure it and do a write mem that it is going to the startup config...you could be out of space on the device and the file never finishes writing.
