A noob issue about recursively routed
Jul 6th, 2009
Hi all,
Here's my configuration.
r2#show ip route
Gateway of last resort is not set is variably subnetted, 2 subnets, 2 masks
C is directly connected, Serial1/0
S [1/0] via
r2#show run int s1/0
interface Serial1/0
ip address
encapsulation frame-relay
r2#show run | include ip route
ip route
Let's ping at r2, can r2 get the icmp reply from ?
Overall Rating: 4 (1 ratings)
dario.didio Mon, 07/06/2009 - 00:18
no, your ping will not work.
If you remove the static route, it will work.
reason is that if you ping, the static route will be used because it is more specific than the connected route. (sh ip route
The destination for the static route is again, and the story goes on...
Why do you want to configure it like this?
wandering_997 Mon, 07/06/2009 - 00:50
Hi Dario,
Thank you for your reply.
Yes, you're right, it does't work.
This is not a requirement, but a accident of my colleague.
I didn't believe that untill I made a lab.
I'm wondering why it exists? It looks like a serious bug of routing mechanism.
And I made a /32 route to a host in the same segment on my laptop system, the host can be pinged successfully.
[email protected]:~> route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface UGH 0 0 0 eth0 U 1 0 0 eth0 U 0 0 0 lo UG 0 0 0 eth0
[email protected]:~> ping -c 1
PING ( 56(84) bytes of data.
64 bytes from icmp_seq=1 ttl=64 time=0.735 ms
--- ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.735/0.735/0.735/0.000 ms
Why? Is IOS different from Unix like system?
