07-06-2009 12:58 AM - edited 03-04-2019 05:19 AM
Dear all,
Normally, Vlan 110 is the best route between Multicast server and Multicast client, and so Multicast also follow the best route to run. Therefore, I can see that the Multicast source is from Vlan 110 in VSS.
However, If I statically add "ip mroute 10.8.8.100 255.255.255.255 10.1.2.34" in VSS.
The Multicast source will be come from Vlan 108. But once the Vlan 108 link is disconnect,
The Multicast source still come from Vlan 108 and will not auto failover to Vlan 110. Why
Result before Vlan 108 disconnect
VSS#sh ip mroute sparse
(*, 239.1.0.0), 00:08:12/stopped, RP 128.8.248.110, flags: SJC
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Vlan11, Forward/Sparse-Dense, 00:06:34/00:02:57
(10.8.8.10, 239.1.0.0), 00:08:12/00:02:55, flags: T
Incoming interface: Vlan108, RPF nbr 10.1.2.34, Mroute, RPF-MFD
Vlan11, Forward/Sparse-Dense, 00:06:34/00:02:57, H
Result AFTER Vlan 108 disconnect
VSS#sh ip route 10.8.8.10
Routing entry for 10.8.0.0/16
Known via "ospf 1", distance 110, metric 2, type inter area
Last update from 10.1.2.254 on Vlan110, 00:01:00 ago
Routing Descriptor Blocks:
* 10.1.2.254, from 10.3.1.1, 00:01:00 ago, via Vlan110
Route metric is 2, traffic share count is 1
07-06-2009 02:34 AM
Multicast routing relies on the current routing table, if you add more specific static routes it will alter the multicast tree.
HTH>
07-06-2009 03:37 AM
"Multicast routing relies on the current routing table . . ."
BTW, footnote: true for PIM variants, not so for multicast routing protocols that maintain their own routing, e.g. DVMRP
07-06-2009 07:08 AM
I don't want to change the normal data routing on the routing table ( best route Vlan 110, Vlan 108 is backup path)
But I want to use Vlan 108 for primary multicast route and Vlan 110 as secondary route
How can I config it ...It seems I can't set two ip mroute in the VSS router which is
ip mroute 10.8.8.10 255.255.255.255 Vlan 108
ip mroute 10.8.8.10 255.255.255.255 Vlan 110 10
07-06-2009 09:53 AM
this will not solve your problem unless vlan 108 completely disconnects. meaning that unless the vlan shows administratively down down or protocol down.
if you make the links point-to-point you may be able to pull it off like this.
to make it a dynamic failover you have to influence unicast routing. since pim depends on the routing protocol for dynamic failover.
also, I assume you have sparse-dense mode commands on both vlan 108 and 110.
hope this helps.
e
07-06-2009 04:59 PM
the way to do floating mroute is such:
ip route 1.1.1.1
ip route 1.1.1.1
ip mroute 10.8.8.10 255.255.255.0 1.1.1.1
where 1.1.1.1 is dummy ip.
i suggested next hop ip instead of vlan108 so to avoid possible arp issue.
your mroute table should point to vlan108 nexthop ip and also as neighbor.
also, as your RP is not on the switch closest to the source, you may need mroute to RP too, but i am not 100% sure. Please let me if you find out.
