David Harper Mon, 07/06/2009 - 02:10
  • Cisco Employee,
You may be able to configure it as a third party SIP device, but it has not been through the CUCM interoperability-test process, and as such, this is not a supported solution.  In any case, the features you would get are very limited.  When you take this into account, as well as the number of CUCM DLUs that would be required, you would probably be better off going with a 7921 or 7925 phone instead.
Cheers,
Dave.
Alberto Montilla Mon, 07/06/2009 - 07:27
  • Cisco Employee,
Dear Sir;
As David said. Yes, it will work for basic functionality (calling, cfwd, conferencing) based on SIP.
However, this is a non-supported configuration (i.e. we dont provide support).
You will need DLUs for a basic phone to have it registered.
Alberto
