access point 1200 series - upgrade to lwapp
Jul 6th, 2009
i' ve a access point 1200 series.
I want to connect it to the WLC but if i try to upgrade it to lwapp , not work.
The tool say that there is a problem with a radio signal.
Can you have a detail procedure for to upgrade this model of ap to lwapp mode?
I see that this access point work only with 2,5ghz end not 5ghz with the ap1240.
can to be this a problem?
thanks for your help
fcostalunga
