VACL, access map
Jul 6th, 2009
I need some help creating an access list for some VLANs.
It`s Cisco 3550s and 3560s
I use to do this the following way:
I create a extended ACL
access-list 101 permit icmp any any ttl-exceeded
I create a access map
vlan access-map ACL101
action drop
match ip address 101
action forward
And apply it to a VLAN
vlan filter ACL101 vlan-list 100
This works great for this purpose.
But now I have a more complex scenario.
I have some IP addresses in a VLAN that should be filtered. And only port 20-23, 25, 37, 53, 80, 110 and 443 should be open for these.
For all other IPs all ports open, except the ones in the other map.
How would I set this up?
Giuseppe Larosa Tue, 07/07/2009 - 05:24
Hello Per,
you can use a positive logic using the implicit deny of both ACL and VACL.
ports means TCP ports and you need to understand on which side are the well-known ports 20-23, 25 and so on.
Let's suppose the selected hosts are servers and have to be accessed only on these services
access-list 121 permit tcp host host1 eq 23 any
this is for permitting telnet to server with ip address host1
similar lines are needed for each host port combination unless the ip addresses are contigous
then you apply
vlan access-map SelectedAccess
action forward
match ip addr 121
no additional blocks are needed
if the hosts are clients of the TCP applications the ports have to be specified at the end of the line
Hope to help
