Cisco 857 not working since ADSL2 upgrade
nickc1976
I have a Cisco 857 router. Recently the ISP (BT) have upgraded the ADSL line to ADSL2. Since then, the router is unable to obtain an internet connection. The CD light flashed constantly, and the PPP light never comes on solid.
There have been no changes to the router config. I tried resetting the router to factory defaults, then giving the router a basic config, but I still get the same result.
My ADSL settings:
Enc: PPPoA(AAL5MUX)
VPI: 0
VCI: 38
Address: IP Negatiated
Authentication: Chap & Pap
As a test, I swapped the Cisco 857 for a Netgear 834, and the Netgear connected straight away.
Can anyone suggest anything I can try?
Nick
Hello Nick,
try the following to download an updated firmware
Try:
ftp://ftp.cisco.com/pub/access/800/
What you want is 3-0-33 FW.
Thanks to Paolo Bevilaqua
Hope to help
Giuseppe
16 Replies 16
andrew.prince
Level 10
Level 10
AFAIK the 857 does not support ADSL 2
HTH>
Nick,
It does support.
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/prod_qas0900aecd8028a982.html
Q. Do the platforms support ADSL2/2+?
A. The Cisco 857, 876, 877 and 877M routers support ADSL2/2+ standards.
Please let me know which ios version you're using and the output of "debug pppatm error". It's good to see your configuration.
HTH,
Toshi
Thanks for your assistance.
IOS version is 2.4
I entered the command "debug pppatm error", and the message "PPP over ATM errors debugging is on" is displayed. But no debug information was shown. Do I need to enter another command to view the output?
Nick
My config
Hello Nick,
post
sh dsl interface atm0
to be noted:
if the provider DSLAM has been upgraded to ADSL2 it can be a problem because ADSL2+ is backward compatible with ADSL but ADSL2 isn't.
Hope to help
Giuseppe
sh dsl interface atm0 is attached
Hello Nick,
as I've suspected there is incompatibility.
you probaly need a firmware upgrade to achieve a working link.
the easiest way to do this is to load a newer IOS image like 12.4(20)T or later.
Edit:
if you look in the forum archive you can find the procedure and the link to download newer firmware.
Hope to help
Giuseppe
Thanks Giuseppe.
Can I download the latest IOS from this website?
Nick
Thanks. I will check it out and let you know how it goes.
Nick
Nick,
Sorry for replying too late. I got a long weekend. As Giuseppe mentioned, you may try to upgrade your ios. However you need to have CCO to access this software. If you've purchased the service you can request user/password from the vendor.
Toshi
I am struggling to find how to download the software. This is what I have done so far.
http://cisco.com
"Products and Services"
"Cisco IOS and NX-OS Software"
Cisco IOS Software Releases > Cisco IOS Software Release 12.4T
Support > Download Software
Log in
Download Software > Select a product
Routers > Cisco 800 Series > Cisco 857 Integrated Services Router
Select a release
Latest Release > 12.4.15T9(MD)
Select the link to the file at bottom of page
"To download this software, you must do all of the following:
Register
Due to United States export compliance regulations, you must be registered on Cisco.com to download this software. If you do not have a Cisco.com username and password, please register now. Registration is free. If you have already registered, please log in to proceed."
I am already logged in!
If I select Log in now, I am returned to the previous page!
Hello Nick,
the CCO account has to be associated to a service contract to be able to download the IOS image.
Contact who has sold you the router.
your account has not enough rights at the moment.
Hope to help
Giuseppe
Hello Nick,
Try:
Hope to help
Giuseppe
Thanks for the link. I downloaded the file adsl_alc_20190.3-0-33.bin
Next I used the command "copy tftp flash" to update the router. I have attached the results - is this correct?
I will test this at the affected office on Monday and post back the results.
Nick
