07-06-2009 05:48 AM - edited 03-06-2019 06:36 AM
Seeing a strange issue on some cat4500s. Trunking to other switches using the GBIC on the supervisor works fine, but trunking on any copper ports has issues and frequently does not work.
Attached sh tech, sh mod and port configuration. The switch that I am trying to connect to trunk has an identical configuration. I do have a few copper ports that are trunking just fine.
This is the error I get in the logs on the 4500.
Jul 01 2009 12:57:15 CDP 4 NATIVE_VLAN_MISMATCH Native VLAN mismatch discovered on FastEthernet5/48 (65535), with na151-423sw1.naismc.com GigabitEthernet0/1 (1).
Jul 01 2009 12:58:16 CDP 4 NATIVE_VLAN_MISMATCH Native VLAN mismatch discovered on FastEthernet5/48 (45), with na151-423sw1.naismc.com GigabitEthernet0/1 (1).
07-06-2009 05:53 AM
David
Can you post output of "sh interface trunk" from the 2 ends of the trunk that are giving errors.
Jon
07-06-2009 06:00 AM
The 3560 is currently not connected as I have a workaround in place. If I take the same 3560 that would not trunk on the copper port on the 4500 and connect it to a downstream switch that is trunked off of the GBIC on the supervisor module the 3560 trunks just fine, which shows me there is nothing wrong with the 3560.
