bundle the uplink ports on FI ?
Answered Question
Jul 6th, 2009
  • Bronze, 100 points or more
Can i "bundle" two uplink ports into an Etherchannel and then statically pin the server ports to the "bundle" (portchannel) and not the individual links ?
regards,
Geert
Correct Answer by bhedlund about 7 years 11 months ago
Geert,
Yes, you absolutely can uplink the FI with a port-channel to VSS or vPC.
See this for a visual of this design:
http://www.internetworkexpert.org/2009/07/05/cisco-ucs-vmware-vswitch-design-cisco-10ge-virtual-adapter/
I think Mike Frase was referring to how the IOM (I/O Module) inside the blade enclosure uplinks to the FI -- and he is correct that port channel is not currently an option for those links.
Cheers,
Brad
p.s. Please rate if helpful
Overall Rating: 5 (1 ratings)
mfrase Tue, 07/07/2009 - 11:25
  • Cisco Employee,
The port-channel concept is not used in the 6100 to I/O mod connection. The High availability architecture of the connections from mezz cards to the network are pinned to provide best configuration and load balance for link failures
gnijs Fri, 07/10/2009 - 03:50
Then i have a problem connecting the FI to a VSS system: it means a single FI can't be dual-connected to VSS switches and traffic will be forced across the VSL link.
Correct Answer
bhedlund Sat, 07/11/2009 - 16:00
  • Silver, 250 points or more
Geert,
Cheers,
Brad
gnijs Mon, 07/13/2009 - 10:51
I did mention an "uplink" port. A FI-IO link is a downstream link or server/host port.
Many thanks for the link. very interesting esx design btw (altough it uses the palo nic which will not be available at fcs, the same for the full-width servers). this is a pitty because i am forced into an esx design with 2 nics only....
