ISDN error message
Jul 6th, 2009
Hi Guys,
I am experiencing an issue with incoming calls on certain numbers within a range of ddi`s. The debug isdn q931 is returning the following:
Jul 6 11:39:59.743 UTC: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0050
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA193040000
Preferred, Channel 4
Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x0083, '4421836482930'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '1234567'
Jul 6 11:39:59.763 UTC: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8050
Channel ID i = 0xA993040000
Exclusive, Channel 4
TK-VCE-RT01#
Jul 6 11:39:59.983 UTC: ISDN Se0/0/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 9, call id 0x1BED, call ref 0x8050, event 0x89
Jul 6 11:39:59.983 UTC: ISDN **ERROR**: Module-l3_sdl_u Function-Ux_BadMsg Error-Source ID = 400 Event = 89
TK-VCE-RT01#
Jul 6 11:40:09.856 UTC: ISDN Se0/0/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 9, call id 0x1BED, call ref 0x8050, event 0x89
Jul 6 11:40:09.856 UTC: ISDN **ERROR**: Module-l3_sdl_u Function-Ux_BadMsg Error-Source ID = 400 Event = 89
Jul 6 11:40:09.992 UTC: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0050
Cause i = 0x82E6333130 - Recovery on timer expiry
Jul 6 11:40:09.996 UTC: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8050
Jul 6 11:40:10.044 UTC: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0050
I have tried adjusting the ISDN timer but this has not made any difference. Does anyone know why this would affect only certain numbers in a range and what can be done to fix this, thanks.
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Mon, 07/06/2009 - 06:37
  • Hall of Fame,
    Founding Member
Exact IOS used ?
paolo bevilacqua Mon, 07/06/2009 - 07:00
  • Hall of Fame,
    Founding Member
Can you use a mainline like 12.4(3j) - much less buggier.
Also check what is going on with these DIDs what the final destination is doing.
sebastiandm Mon, 07/06/2009 - 07:09
Hi Bevil,
Unless i can definately prove it is an IOS issue it would be a bit difficult to change the IOS.
When the call comes in i have a translation rule which is translating this number into 0201010 which is a mobile voice access number.
I then have a pots dial peer and a voip dial peer to match this newly translated number but it is not even hitting my pots dial peer, config is as follows :
dial-peer voice 0201010 pots
description Mobile Voice Access
service ccm
incoming called-number 0201010
no digit-strip
dial-peer voice 124 voip
description Mobile Voice Access Calls
preference 1
destination-pattern 0201010
progress_ind setup enable 3
session target ipv4:10.10.10.10
dtmf-relay h245-alphanumeric
no vad
When dialling this number in particular i get a message from the carrier something about the call not being completed its in Tokyo.
If i ring another number in the same range it goes through perfectly fine.
paolo bevilacqua Mon, 07/06/2009 - 07:30
  • Hall of Fame,
    Founding Member
I don't have to prove anything, the abnormality is evident.
Either "service ccm" does something wrong, or router becomes confused so telco disconnects.
sebastiandm Mon, 07/06/2009 - 07:37
Sorry i think you misunderstood what i was saying. I am not asking you to prove something i just mean my client would want me to be sure it is the IOS before letting me change it. I do agree with you tho so sorry if it sounded wrong.
I will try remove the config altogether and start again in case something has been missed.
Thanks for taking a look i appreciate it.
andres.pasten Fri, 09/04/2009 - 06:47
This message resolved my problem!!
I've been trying to resolve the same error for more than 5 days, and it's not a problem of configuration, only IOS.
The 12.4T IOS drops the call because of facility information that comes from the PBX, but the mainline IOS doesn't.
Thanks!!
Andres Pasten
Adexus S.A.
