CEoIP PBX end to end loopback
mugahid-mustafa
I have 2x3845 with CEM E1 connecting to NEC PBX. the CEM circuit is up but i can't perform loopback test to the PBX to other PBX side.
I tried to use loopback network forn the E1 router controller, and i am getting nothing at the PBX site.
loopback local line from each Router to the PBX on the same site is OK.
Advice
Thanks & Regards
paolo bevilacqua
Use an RJ45 loopback plug.
I tried, but i can't get singnal/flash on the BPX on the other end.
I will move 1 router to the other site and i will connect both back-to-back, and then i will perform loopback.
hope it will work
Hi All,
How to check weather there is a traffic passing throuhg CEoIP circuit.
Any debug, or capture application?
Thnx
