ASA 5510 site to site VPN
Jul 6th, 2009
I have two identical ASA 5510's and would like to create a tunnel between them so that I can replicate backup data. My old 281l's at each end could not handle the traffic. On my data center end I use 198.61.64.0 /17 and 198.90.152.0 /24 on the other end I use 198.61.74.0 /24 198.61.89.0 /24 and 198.90.153.0 /24. Can someone provide me the correct local network and remote network settings for both ends? My question is whether or the the ASA will get confused since the DR nets are in the /17 range of my datacenter. I use eigrp and some static routes, to route the traffic. Thanks.
htarra Fri, 07/10/2009 - 13:35
  • Bronze, 100 points or more
Add the following on both devices.
crypto isakmp identity address.
