ASA and ACS 5.0 Radius Group
Jul 6th, 2009
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808cf897.shtml
Following this note I try to assign an asa group policy through our ACS. The only difference is ACS v5.
I correctly set ACS to send the ou=group in the IETF[25] Class attribute. But debugging radius on asa i see the following arriving and not the ou= group :
Radius: Type = 25 (0x19) Class
Radius: Length = 22 (0x16)
Radius: Value (String) =
41 43 53 30 31 2f 33 34 31 31 36 39 35 39 2f 38 | ACS01/34116959/8
38 35 35 38 | 8558
Does someone experienced the same and have a solution ?
tprendergast Mon, 07/06/2009 - 11:22
Can you please paste the contents of the IETF 25 Class variable box from the group?
Verify the user you are authenticating is a member of that group, as well, so the attribute is returned.
ccr_cisco Tue, 07/07/2009 - 01:23
Here is the radius attribute box screenshot for the group. I can see on the ACS log that the user is on the group and that the good authorization profile is applied.
Thanks for your help
I have a question for you, you could help me please?
The problem:
we have a problem for authentication a remote access VPN (ASA 5510, version 8.2.1) with ACS 5.0 (version 5.0.21), but its not working.
When I try with ACS 4.1, the authentication work fine.
could you tell me what is your version ACS and ASA??
your system is working ok????
Regards.
Marco
