Translation problem
Jul 6th, 2009
We are getting a new ISDN bearer installed on our MGCP VGW. The provider has given a range of 8150-8399 which overlaps with our own 8xxx. The only spare range in the CUCM is 1400-1649. IS there an easy way to do this. I was thinking of creating a new CSS and partition and adding new translation patterns?
All ideas welcome
Simon
Jaime Valencia Mon, 07/06/2009 - 08:41
  • Cisco Employee,
  • Hall of Fame,
    2011
Since this is MGCP there are really not many options, you'll need to start summarizing as much as possible the patterns to translate them into the available pattern.
The other option would be to add a prefix so those are 5 digits and then do not overlap
java
if this helps, please rate
simonmossman Tue, 07/07/2009 - 03:14
Thanks for the prompt response Java. Always as helpful as ever......damn MGCP
All the best
Simon
