How do I telnet into my 4404 Controller
Jul 6th, 2009
How do I telnet into my 4404 controller. I can reach it through its webpage and login but when I type the same IP I used it states I can't connect.
dancampb Mon, 07/06/2009 - 10:11
  • Cisco Employee,
Telnet is disabled by default on the controllers. You can enable it under the Management - Telnet/SSH page or with the command "config network telnet enable"
Leo Laohoo Mon, 07/06/2009 - 14:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Telnet, by default, is disabled. Try SSH. If not do what Dan has described and enable Telnet via HTML or HTTPS.
I do not encourage/recommend unsecure access to the WLC via Telnet and/or HTTP.
Hope this helps.
