7941G boot problem
Jul 6th, 2009
I have 5 7941G phones that won't boot. the speaker turns green as if it is going to boot up, but after about a minute the mute button will start doing quick red flashes every few seconds. nothing comes up on the LCD or any of the other buttons.
thanks for any help you can provide.
KM
paolo bevilacqua Mon, 07/06/2009 - 15:51
  • Hall of Fame,
    Founding Member
You need to connect them to a CM, CME or DHCP/TFTP server so they can reload firmware image to flash.
redrobish Tue, 07/28/2009 - 20:25
You could connect the phone directly to the PC's nic that have the TFTP software. You should have downloaded the firmware needed for that phone unit.Reboot. That should fix it.
hth
davidlu766 Thu, 07/30/2009 - 12:59
Did you get it to work? I am actually facing similar problem after doing a factory restore on the 7941G
Please let me know.
Thanks.
Yes, it worked like a dream! I now have 12 phones that I thought were scrap, all working. After downloading the firmware from Cisco, I used TFTPd32 (which has it's own DHCP server), a crossover cable and directly connected each phone to the PC running TFTP. On booting the phones, they flashed and worked. Let me know if you need more info.
davidlu766 Fri, 07/31/2009 - 13:08
Hmmm, it just won't work for me...
What OS are you running? I have vista... and every time I run the program it gave an error saying that some other application is listening to the DHCP port. Also I thought that if windows has a pc has a dhcp server I wouldn't need any crossover cable...??? Any ideas?
Please help...
Hi... I'm using XP. I think the first thing you will need to do is set the IP address of your PC's network card to a fixed IP address - I used 192.168.0.1, subnet 255.255.255.0. On the DHCP server tab of TFTPd32, I used a Pool start address of 192.168.0.2 and set a pool of 50.
I think the thing listening on the DHCP port is your own PC - by setting a fixed address, dhcp is effectively disabled, but TFTPd32 acts as the dhcp server then.
davidlu766 Sun, 08/02/2009 - 23:44
But do you still need a crossover cable in order to get it to work?
Thanks.
