how long should the logs last? (sawmill)
Jul 6th, 2009
it seems the logs can only be shown for the entire two weeks.
is there a possibility to make it 3 months? or is there any retention period?
if there's any thread/documents/KB link
please post
jowolfer Mon, 07/06/2009 - 15:43
I'm somewhat confused by your post. Log files have no expiration time. The accesslog files will be built into the Sawmill database and from there exist until you purge the database.
There are no auto processes that will remove the source log files or purge the database (though I highly recommend scheduling a purge process so that the Sawmill DB doesn't grow to become too large to process in a timely fashion.)
rommel1981 Fri, 07/17/2009 - 03:16
i can't seem to view logs from a month or 2 months ago. i will try to explore more of the sawmill. i'll get back to this thread if i find something
