IPS Auto update - http error response
Jul 6th, 2009
I am having trouble doing auto signature update on my AIP-SSM. This is what i am getting on #show statistics host
Auto Update Statistics
lastDirectoryReadAttempt = 11:00:08 GMT+08:00 Mon Jul 06 2009
= Read directory: https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl
= Error: http error response: 500
lastDownloadAttempt = N/A
lastInstallAttempt = N/A
nextAttempt = 12:00:00 GMT+08:00 Mon Jul 06 2009
Fyi..my CCO credentials are perfectly fine, as i am able to download signature files manually from Cisco Download site.
Please advise
wong34539@yahoo.com Fri, 07/10/2009 - 14:21
If you are looking at the Auto Update Statistics in your sh tech, you can see a "http error response: 500" This is an internal web server error. Are you sure there is nothing between the AIP-SSM and the internet besides the ASA? Maybe there is an embedded web server like Barracuda? Do you know if your ISP is providing proxy services for you?
J_Vansen_S Fri, 07/10/2009 - 19:07
hi wong, thanks for ur reply.
Apparently there isnt any web server running. no proxy services too. hmm..i still cant think of whats wrong. It purely just clean..
Internet--ASA-IPS
The ips segment has access to the internet
JACQUES DU PLESSIS Mon, 07/13/2009 - 02:17
Hi, just something I found, the error code refers to http, not https. It seems like the IPS connects port 443 to .25 initially and then port 80 to .243
Jacques
