Wait seize acknowledgement from router side
Jul 6th, 2009
I have a testing setup, discription is following:-
1)Cisco 3845 router with VWIC2-2MFT-E1/T1 port is connected with E1(DTMF)card of BPL EPABX with patch cord.
2)The same senario is working with Cisco 2851 router with VWIC2-1MFT-E1/T1 port.
3) Both routers are connected with 2MB Leased line.
The routers are using "e&m-immdiate-start" signal type.The EPABX is waiting for "wait seize acknowledgement" signal, that why call is not through.
Can anyone tell me that router can generate "wait seize acknowledgement"?
If Yes, please tell me by which command?
Siddhartha
