enable SSH for Cisco 6509
Jul 6th, 2009
Hi everybody,
I want to enable SSH instead of TELNET to manage the Cisco 6509 ,but i find that
the cisco 6509 don't have ssh option .
can anyone tell me the cisco 6509 support ssh or not ? IOS version is "Version 12.2(18)SXF13" .
S3(config-line)#transport input ?
all All protocols
lat DEC LAT protocol
mop DEC MOP Remote Console Protocol
nasi NASI protocol
none No protocols
pad X.3 PAD
rlogin Unix rlogin protocol
telnet TCP/IP Telnet protocol
udptn UDPTN async via UDP protocol
Overall Rating: 5 (2 ratings)
dario.didio Tue, 07/07/2009 - 00:01
do a show version on your box. You will see the filename which is something like s72033-ipservicesk9_wan-mz.122-18.SXF13.bin
If it has the "k9" in it, then you can use SSH because it supports encryption, if it doesn't have it, then it is not supported and you should perform a software upgrade to support it.
Pls rate if this was useful for you.
liuguiqing Tue, 07/07/2009 - 17:28
Hi Dario,
Thanks for you great help first .
It doessn't have the "k9" in it .
IOS (tm) s3223_rp Software (s3223_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF13, R
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Thu 14-Feb-08 00:07 by kellythw
Image text-base: 0x40101040, data-base: 0x42A40EB0
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: s3223_rp Software (s3223_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF13, R
S3-768-10G uptime is 18 weeks, 4 days, 17 hours, 49 minutes
Time since S3-768-10G switched to active is 18 weeks, 4 days, 17 hours, 48 minut
System returned to ROM by power cycle (SP by power on)
System restarted at 23:34:43 PST Thu Feb 26 2009
System image file is "sup-bootdisk:s3223-ipservices_wan-mz-1.122-18.SXF13.bin"
cisco WS-C6509 (R7000) processor (revision 3.0) with 458752K/65536K bytes of mem
Processor board ID TSC0652002X
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
111 Virtual Ethernet/IEEE 802.3 interfaces
96 FastEthernet/IEEE 802.3 interfaces
17 Gigabit Ethernet/IEEE 802.3 interfaces
2 Ten Gigabit Ethernet/IEEE 802.3 interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x0 (will be 0x2102 at next reload)
