VPN on Vista 64bit
Jul 6th, 2009
In my enterprise, we migrate our computers XP to Vista 64bit.
Now, we have some problems to create a VPN with an ASA 5505.
In fact, on XP and Vista 32bit, the VPN connection works great.
I did some research on the web but I haven't found the solution. I saw i'm not alone to have this trouble.
Can you help me ?
Many Thanks.
/* Sorry for my bad english */
Collin Clark Tue, 07/07/2009 - 05:11
The traditional IPSec client is not supported on x64 systems. You must use the AnyConnect client which requires SSLVPN licensing.
Hope that helps.
andrewswanson Wed, 07/08/2009 - 02:25
you can also use VMs running a 32 bit OS with Cisco VPN - its a fair bit of extra work but can be used as a stop gap while you migrate to AnyConnect.
hth
andy
vpnhaus_SF Tue, 09/08/2009 - 11:22
Hi Stephane,
Are you looking for a stand alone client or an enterprise solution? For both cases, you should look in to NCP engineering (www.ncp-e.com). They have solutions that are compatible with several OS', including, Vista 64 bit.
Check out NCP Secure Entry Client or NCP Secure Enterprise Client. Additional information about both can be found here: http://www.ncp-e.com/en/solutions/vpn-products.html
Hope this helps.
Phillip Remaker Fri, 02/19/2010 - 11:14
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
