Offline Viewer for CUCM CDR Data
Jul 6th, 2009
Is it possible to view CDR data backed up from the CUCM by means of a offline viewer application. Are there such applications.
Is the CDR data needs to be analyzed in a future date using the old backup, how can this be achieved.
Thanks.
Nikolay Kozyrev Thu, 11/29/2012 - 22:56
I have the same questuion now. Did you find any CDR Viewer application ?
Cheers.
Harmit Singh Thu, 11/29/2012 - 23:34
  • Cisco Employee,
Hi Nikolay,
You can either use the CDR Analysis and Reporting Tool (CAR) inbuilt in the CUCM. However a better option would be to configure a 3rd party billing server and have the CUCM push the CDR data onto it so as to view the data and generate reports on it independant to the CUCM. This can also be used for looking at historical / archived CDR data. The following doc should be able to shed more light on this:
https://supportforums.cisco.com/docs/DOC-13842#Billing_Servers
HTH.
Harmit.
Nikolay Kozyrev Fri, 11/30/2012 - 00:06
Hi, Harmit.
Ok ..will do..but now i has a situation when i need and analize a CDR files ( CAR+CDR) from RTMT Tool and I has no Billing server. I have no CDR txt file - only CDR + CAR files.  Any ideas ?
Chris Lee Thu, 12/06/2012 - 22:39
Hi Nikolay,
I don't know if this would work exactly for you but it might help -
csshenoy80 Fri, 12/07/2012 - 08:40
Hi Chris,
What is the tool used for the above?
Chris Lee Fri, 12/07/2012 - 08:51
This web-based software tool is called Variphy Insight and it takes the CUCM call data (both the CDR and CMR logs), and processes them into a SQL database (either MySQL or MS SQL).  Once in the SQL database, you can run queries, create reports, schedule reports delivered via email with Variphy Insight.  Submit online for a free download that's a full-version, no-feature-handicap trial - 90 days.
Chris
