Warning message
CCA 2.0(1) stuck in Telephone Setup Wizard
Jul 7th, 2009
I recently upgraded my uc520 with the new software UC520-7.0.3.
I did that with the new cca 2.0(1)
Everything went fine.
But after the upgrade, i cannot use the Telephony Wizard.
The progress bar gets stuck at 95%.
I read that this should be fixed in the cca release 2.0(1), but it is still not working.
Is there  a workaround or a fix for this?
regards,
Sven
sknockae Tue, 07/07/2009 - 14:24
I installed the whole software pack again and now it works fine!
Tomoo Esaka Tue, 07/07/2009 - 15:01
  • Cisco Employee,
Sven,
Glad to hear the good news. If you still have access, could you unicast me the CCA troubleshooting logs for when your TSW got stuck at 95%? Procedure is below.
http://www.myciscocommunity.com/servlet/JiveServlet/previewBody/1556-102-1-1923/CCA_troubleshooting_log.pdf
Or if you don't have access to UC500, Application logs can be retrieved from:
C:\Program Files\Cisco Systems\CiscoSMB\Cisco Configuration Assistant\Application_Logxxx
Tomoo
Related Content
