B-ACD in cme 7.1
Jul 7th, 2009
We have a B-acd being configured in a Cisco 2811 router.After the config for B-acd is done, i am not able to receive calls on the DNIS number as a disconnect tone/number not in use is received.
The configuration is
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
paramspace english index 1
param number-of-hunt-grps 2
param handoff-string aa
param dial-by-extension-option 1
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 26268648
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param max-time-call-retry 700
param service-name queue
service queue flash:app-b-acd-3.0.0.2.tcl
param queue-len 15
param aa-hunt1 7000
param aa-hunt2 8000
param queue-manager-debugs 1
dial-peer voice 2 voip
service aa
destination-pattern 26268648
session protocol sipv2
session target ipv4:192.168.204.1
incoming called-number 26268648
dtmf-relay rtp-nte
codec g729br8
Respectively 7000 and 8000 are configured as hunt-groups with 2 members each.
Am i missing any configuration for B-acd to work.
Kumar
russ.kwong Wed, 07/08/2009 - 18:20
Dear Kumar,
Because some part of configuration, I can suggest some step to check it,
1) The dial-peer is set to voip ? not pots ?
2) The destination-pattern 8 digit ?
Would you please check the incoming number really hit the pattern?
Hope this message can help you.
russ
bgrunewald Tue, 07/14/2009 - 11:09
You might be missing a mandatory parameter in the AA. Run "deb voice appl script" and that should tell you.
I have one working with this B-ACD version, and have more params, but not sure which are required.
Also, my VoIP peer is not SIP. My pilot number is 505 and looks like:
dial-peer voice 505 voip
service aa
destination-pattern 505
incoming called-number 505
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Not sure if SIP vs. H323 makes a difference, but it works.
