support for Cisco VPN client and Anyconnect client
Jul 7th, 2009
does any know if the Cisco VPN client and AnyConnect client is supported on the for the same ASA using the same laptop?
I had the VPN client working and clientless SSL working. But once I used AnyConnect on my laptop, the VPN client stopped working.
The VPN client establishes a tunnel. I can see the client in the ASA routing table, but it isn't routing.
The VPN client and AnyConnect clients use the same group-policy just the tunnel-groups are different (due to ipsec and svc)
Collin Clark Tue, 07/07/2009 - 05:12
  • Purple, 4500 points or more
I have both working to the same site on my laptop (XP 32-bit).
