STATIC NAT - INSIDE TO OUTSIDE
Hi netpro's
I am having a nightmare time trying to get some static nat working on the pix...
I have PIX 515 V8.2
inside i have 192.168.204.0 /22 network
outside I have 192.168.1.0 /24 network
the outside interface is connected to a cisco 877 router with a FTP server connected to one of the interface's on the 877 with an IP of 192.168.1.50.
I need to add a static map on the PIX inside interface that maps inside address 192.168.207.100 to the FTP server IP 192.168.1.50
I have added the following commands and it doesn't work !!!
static (inside.outside) 192.168.1.50 192.168.207.100 netmask 255.255.255.255
nat-control is disabled, and there is not other NAT or PAT configuraitons on the PIX.
What am I missing?
Rod
Overall Rating: 3 (1 ratings)
Jon Marshall Tue, 07/07/2009 - 02:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rod
Try this
static (outside,inside) 192.168.207.100 192.168.1.50 netmask 255.255.255.255
Jon
Hi John,
Thanks for the response. I tried your sugesstion and something strange happend.
I tried to remote desktop onto the FTP server via the 192.168.207.100 address and got as far as seeing the server screen, however the connection dropped before I could be presented with ctrl and delete screen from the server....
any suggestions?
rod
config below:
PIX Version 8.0(3)
hostname pixfirewall
domain-name corp.rwenukem.co.uk
enable password gtNhcavDCYG3V2bP encrypted
names
interface Ethernet0
nameif Outside
security-level 0
ip address 192.168.1.100 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.207.1 255.255.252.0
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
access-list out2in extended permit tcp host 192.168.1.50 any
access-list out2in extended permit tcp host 192.168.1.66 any
access-list out2in extended permit tcp host 192.168.1.1 any
access-list in2out extended permit ip any any
pager lines 24
logging enable
logging console debugging
logging monitor debugging
logging asdm debugging
no logging message 710005
mtu Outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-603.bin
no asdm history enable
arp timeout 14400
static (Outside,inside) 192.168.207.100 192.168.1.50 netmask 255.255.255.255
access-group out2in in interface Outside
access-group in2out in interface inside
route Outside 0.0.0.0 0.0.0.0 192.168.1.1 1
route inside 192.168.200.0 255.255.255.0 192.168.204.3 1
route inside 192.168.201.0 255.255.255.0 192.168.204.3 1
route inside 192.168.202.0 255.255.255.0 192.168.204.3 1
route inside 192.168.203.0 255.255.255.0 192.168.204.3 1
route inside 192.168.208.0 255.255.252.0 192.168.204.3 1
route inside 192.168.214.0 255.255.255.0 192.168.204.3 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 192.168.204.0 255.255.252.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet 192.168.204.0 255.255.252.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
username djrodb password hW62dJ9ElnD4Te0O encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:c834da0a5217b69b71892500f83e5170
: end
pixfirewall(config)#
Jon Marshall Tue, 07/07/2009 - 03:05
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rod
Not sure what is happening there without more details.
Just to clarify -
static (inside,outside) 192.168.1.50 192.168.207.100 netmask 255.255.255.255
means translate the source IP address of 192.168.207.100 to 192.168.1.50
that's why it wasn't working for you.
means translate the destination address of 192.168.207.100 to 192.168.1.50
which is what you need.
So you now have the right static statement but a problem with the server by the sounds of it. Is there any other connectivity test you could try from the inside to the server ?
Jon
