QoS show commands in Cat4500
Jul 7th, 2009
Is there any show commands in Catalyst 4500 that can see we can use to see queuing statistics, e.g, counters to show how many packets are dropped/queued in a particular queue?
So far i only see
show qos
show qos dbl
show qos interface
show qos maps
which does not show what i wanted to see.
Any idea?
Eng Wee
e-chuah Tue, 07/07/2009 - 05:39
HiEdison,
Thanks for the reply. But it looks like it is only applicable when u use policing. If i have the below auto-qos config that does only queueing, does the show policy-map command still provide the same output? (sorry, i do not have a cat4500 to try it out right now)
policy-map autoqos-voip-policy
class class-default
dbl
interface GigabitEthernet3/1
service-policy output autoqos-voip-policy
qos trust cos
auto qos voip trust
tx-queue 1
shape percent 10
tx-queue 3
priority high
shape percent 33
Thanks for your help.
Rgds
Eng Wee
Edison Ortiz Tue, 07/07/2009 - 05:49
  • Hall of Fame,
    Founding Member
The commands you posted along with 'show policy-map interface' are the only commands available for QoS troubleshooting in the 4500. Since most switches employ Hardware-Based QoS, granular information will be missing from its statistics.
__
Edison.
jedellerby Fri, 11/06/2009 - 01:21
The commands I use on a 4500 for checking QoS counters/general QoS info are:
show interface counter all module x
show interface x/y counter detail
show platform hardware qos interface gigabitEthernet x/y
show qos int x/y
These should give you the QoS counters showing per queue counters, per queue drops and DBL drops when DBL is enabled,
Jed
