07-07-2009 05:56 AM
I have several jobs in RME that have a status "running" even after numerous CiscoWorks Daemon restarts, server restarts, etc.
Is there any way to get them to be gone? If I try to delete the jobs, CiscoWorks tells me the job is running.
Rob
07-07-2009 06:41 AM
Which versions of LMS and RME? What type(s) of jobs. What's the exact error message?
07-07-2009 06:50 AM
Two Examples below with Ver #'s....
LMS 1.1.0
RME 4.2.0
Archive Management job
1040 ArchiveMgmt Failed Sync Archive username Mar 24 2009 16:58:10 - Immediate
RMEJOB0004: Could not delete following jobs: 1040
This is because these jobs may be running.
________________________________________
1117 ConfigEditorJob Stop Initiated Config Quick Deploy username Mar 26 2009 13:56:13 - Immediate
RMEJOB0004: Could not delete following jobs: 1117
07-07-2009 07:50 AM
07-07-2009 08:41 AM
I'd guess I need to spend the $ on Smartnet for CiscoWorks. Looks like the TAC might hold the answer, unless Joe wants to chime in on this one.
Rob
07-08-2009 12:38 AM
can you post the output of pdshow?
have you yet tried any steps to delete the jobs from cli? If yes, what have you done?
07-08-2009 01:02 AM
Rob,
if you make use of the rating system to mark a response with '1' (Not Helpful), you should consider to use the rating system also to mark answers as helpful.
If your problem was solved, it is a good practice to mark it as such so others can easily see that a thread includes a solution.
thank you,
mermel
... an answer can be helpful even if it does not include the solution...
