07-07-2009 06:15 AM - edited 03-14-2019 04:19 AM
Hello, i have an issue,i am deploying Contact Center Express 5.0,
is it possible to route incoming call with specific number to the specific agent, i mean, if the VIP pearson is calling, this call redirects to the specific agent,
Solved! Go to Solution.
07-08-2009 11:46 AM
Yes; this is called Agent Based Routing and is explain in the documentation. Note that you cannot queue a contact to an agent. If the agent is busy or does not accept the call, you will need to provide other options. This is typically "try the agent first, then fall into a general queue."
07-08-2009 11:46 AM
