VPN Cisco Client
Jul 7th, 2009
I've configured two IPsec VPN, one site to site VPN between two routers cisco 2811 and the other between one of the routers and a VPN Cisco Client.
But, I have one problem. If I add the command for the VPN Cisco Client:
crypto map IPSEC_VPN client authentication list userauthen
the other vpn is never up, and if I remove it I don't know the security implications, because I can connectonly with the VPN client user and password, but without router user and password.
Could anybody tell me the better way to configure this two VPN?
This is the current configuration:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp key mykey address xxx.xxx.xxx.xxx
crypto isakmp client configuration group 1client
key 123
pool ippool
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
reverse-route
crypto map IPSEC_VPN isakmp authorization list groupauthor
crypto map IPSEC_VPN client configuration address respond
crypto map IPSEC_VPN 3 ipsec-isakmp
set peer xxx.xxx.xxx.xxx
set transform-set ESP-3DES-SHA
match address 103
crypto map IPSEC_VPN 10 ipsec-isakmp dynamic dynmap
interface Tunnel1
ip address 10.1.1.14 255.255.255.252
keepalive 10 3
tunnel source FastEthernet0/0
tunnel destination xxx.xxx.xxx.xxx
interface FastEthernet0/0
description Interface WAN
ip address xxx.xxx.xxx.xxx 255.255.255.248
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip nat inside
load-interval 30
ip local pool ippool 192.168.2.100 192.168.2.110
Thanks and regards
Todd Pula Tue, 07/07/2009 - 09:51
  • Silver, 250 points or more
You will want to modify the client config to utilize an ISAKMP profile. This will allow you to associate the authentication and authorization commands with the dynamic map as opposed to the crypto map. Please see the attached sample config.
usuario0001 Thu, 07/09/2009 - 00:09
Thanks for your help.
I'm modifying the config but I have a doubt, if my LAN is 192.168.2.0, how do I configure the access-list 150?
access-list 150 permit ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
And also, I had these two ACL and I don't know if are needed now:
access-list 102 deny ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
Thanks and regards
Todd Pula Thu, 07/09/2009 - 05:46
Can you attach your current config so I can review as I don't see where ACL 150 or 102 are applied in the partial config above.
