logging in clean access agent with the same login and pass for 2000 users
Jul 7th, 2009
I have 2000 users and i want to use the same login and password for CAA clean access agent for all of them.
it is possible to do that without problem?
srue Tue, 07/07/2009 - 07:59
why would you want to do that?
if you want them all to have the same profile applied then just set a default profile.
srue Tue, 07/07/2009 - 08:13
if you really want to do that, just disable SSO and have all 2000 users manually type in the username and password.
saad_filali Wed, 07/08/2009 - 01:00
I want to verify the conformity of the client poste without authentication or at least one shared login and password of all users.
I need the authentication of CAA the be transparant for final user.
srue Wed, 07/08/2009 - 05:49
you can see which profile a user login belongs to once they log in through the GUI..or by using the Test function in the GUI as well.
