Lobby Ambassador Guest Account Provisioning - via SNMP
Jul 7th, 2009
Hi all,
Has anyone setup a way of provision guest users from an SNMP server using the "config netuser" command so you dont have to use Lobby Ambassador and can use your own provisioning system?
Many thx indeed,
Ken
Lucien Avramov Tue, 07/14/2009 - 12:59
  • Red, 2250 points or more
WCS uses SNMP to create them on the WLC.
The problem with using snmp manually is that they keep on changing the snmp oids on the controllers. If you reverse engineering it with packet captures, after an update of controller you may not find again the snmpset commands to do that from CLI.
That would be the only way I can think of creating users not over GUI.
bhhanson Thu, 02/11/2010 - 18:36
so, wondering if this has been done by anyone??
seems that it would be all too useful for setting up and maintaining these guest accounts.
emulate the WCS actions via SNMP.
any comments woudl be much appreciated..
maybe we will just post what we find.
Trending Topics - Security & Network
