configuration for client vpn access on a loopback interface
Jul 7th, 2009
Hi all,
We tried to configure a router as server for a client VPN .
We applied the crypto map on a loopback interface.
we put "crypto map VpnConn local-address Loopback0".
We can connect using a cisco VPN client but we cannot ping the LAN, even the ip address of the LAN interface of the router configured as server.
How could we solve this?
harinirina Wed, 07/08/2009 - 05:38
Thanks for the doc.
it seems NAT-T is enabled by default in Cisco IOS.
We use a router cisco as VPN Server and we don't know what to add.
Here below our config so you could tell what's wrong and what's missing.
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network Grp local
aaa authentication login Usr local
username uuuu privilege 15 password pppp
interface l0
crypto map IntVpn
interface FastEthernet0/0
ip address W.W.W.1 255.255.255.240
ip nat outside
interface FastEthernet0/1
description vers LAN
ip address R.R.R.1 255.255.255.0
ip nat inside
ip local pool poolVpn P.P.P.1 P.P.P.254
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 deny ip R.R.R.0 0.0.0.255 P.P.P.0 0.0.0.255
access-list 100 deny icmp R.R.R.0 0.0.0.255 P.P.P.0 0.0.0.255
access-list 100 permit ip R.R.R.0 0.0.0.255 any
crypto isakmp policy 5
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group ClGrp
key kkkk
pool poolVpn
acl 199
crypto isakmp profile ClPrf
match identity group ClGrp
client authentication list Usr
isakmp authorization list Grp
client configuration address respond
crypto ipsec transform-set TrSet esp-aes esp-sha-hmac
crypto dynamic-map dynVpn 5
set transform-set TrSet
set isakmp-profile ClPrf
reverse-route
crypto map IntVpn 3 ipsec-isakmp dynamic dynVpn
access-list 199 permit ip R.R.R.0 0.0.0.255 P.P.P.0 0.0.0.255
