Warning message
Problems with LAPs 1252 and WLC 4400
Answered Question
Jul 7th, 2009
I have problem with clients performance in LAPs 1252 and WLC 4400. When the clients are connected they have slow transfering, around 800ms in ping command. Somebody can help me ?
Correct Answer by Leo Laohoo about 8 years 1 month ago
What about event logs from the APs?
Overall Rating: 0 (1 ratings)
Leo Laohoo Tue, 07/07/2009 - 14:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
How many clients are affected? Are the affected clients associate/authenticate to ALL your AP's or just one in general?
Console into your AP in question and check the logs. If you can't console in, you can debug into the LAP by CLI into the WLC and perform the following commands:
1. config ap debug enable
2. config ap debug command "enter command here in between the quotes"
When you are done, don't forget to disable the debug.
3. config ap debug disable
Hope this helps.
NOTE: Thanks to Edison Ortiz for the debug stuff! :)
jcardozo Tue, 07/07/2009 - 15:16
Hi Leo Laohoo, thanks for your help.
I have 12 APs, some have around 30 Clients others 6 Clients, but when I have problem afect all the Clients in all the APs. The Controller have 2 Interfaces in LAG, and I have 12 WLANs with the proper ID and proper virtual interface. All WLANs are in the same group and all APs are broadcasting all SSID.
Thanks.
Correct Answer
Leo Laohoo Tue, 07/07/2009 - 16:08
  • Hall of Fame,
    2017 LAN, Wireless
jcardozo Tue, 07/07/2009 - 16:24
I will get it and tomorrow I tell you the results.
Thanks a lot.
