Bandwidth Monitoring Question
Jul 7th, 2009
Does anybody know what might cause a Network Monitoring Tool to report that a router interface is over 100% utilization? For instance our Solarwinds Orion Server reports that a FastEthernet connection provisioned for 50 Mbps (configured with a bandwidth 50000 statement) and is connected to an ATM Switch sometimes reports 150% utilization. Monitoring is being done via SNMP. The only time I've ever heard of this is for esoteric Frame Relay configurations with dynamic routing protocols that use bandwidth as a metric (say EIGRP for example.)
Any insight that anybody can offer would be appreciated.
Collin Clark Tue, 07/07/2009 - 13:15
  • Purple, 4500 points or more
I'm assuming that you have configured the bandwidth speed in NPM correctly. That being said it is a common problem in NPM. Search Thwack for over utilization and you'll see some posts on it.
Hope that helps.
